Saddle Slot Angle http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=56822 |
Author: | Chris Ensor [ Fri Oct 04, 2024 2:05 pm ] |
Post subject: | Saddle Slot Angle |
How do you prefer to set the angle of your saddle slot? Do you calculate the angle? Measure the slope over a certain distance (1/8" over 3" per Cumpiano)? Or some other method? |
Author: | bluescreek [ Fri Oct 04, 2024 2:25 pm ] |
Post subject: | Re: Saddle Slot Angle |
Martin uses a 3 degree angle gibson used under 4 over 3 I find the 3 degree angle with a .1 saddle slot will afford you ample adjustment for intonation compensation I have actually set guitar bridges unslotted and with a drill blank set the strings for the best intonation , that is were I found the slightly wider saddle on a 3 degree angle works pretty well. I also use .1 compensation length based off the first string and 2.25 on the the bass . So in a nutshell the bass is 1/8 inch longer than the treble. |
Author: | meddlingfool [ Fri Oct 04, 2024 3:31 pm ] |
Mine is a 4mm offset measured at the e strings… |
Author: | rmmottola [ Fri Oct 04, 2024 6:07 pm ] |
I never actually made use of an angle for positioning the bridge slots of steel string acoustic guitars (there seem to be a lot of different conventions used), relying on the compensation calculations from the Fretted Instrument Bridge Saddle Compensation Calculator https://www.liutaiomottola.com/formulae/compensation.htm on my website, or the plan detail as generated by "G" Thang https://www.liutaiomottola.com/formulae/gthang.htm. So I was curious about this as well. Looking at the output of those tools for a conventional steel string acoustic guitar with typical action and string set, the angle comes in at exactly 3 degrees. |
Author: | Terence Kennedy [ Fri Oct 04, 2024 6:36 pm ] |
Always a 1/8” drop back over three inches. With a 1/8” saddle I have never had problems getting good intonation points. I’ll have to measure the angle. |
Author: | Mike_P [ Fri Oct 04, 2024 8:30 pm ] |
numbers.... 1/8" tilt divided by spacing of let's say 2 1/4" = .055555556 take the arc tangent of that and the angle = 3.18* 2 5/16" spacing gives 3.09* hey, just call it a nice even 3* ![]() over a 3" run you get 2.39* |
Author: | Hesh [ Sat Oct 05, 2024 2:29 am ] |
3 degrees. |
